SSID Password Change
Shadius
Hey all,
Is there a way to change the password of all the SSIDs I have altogether?
I have multiple sites with multiple Cisco Meraki wireless access points. When it's time to change the password for each SSID, I don't want to have to go into each individual site's SSID and manually change the password every time.
Thanks in advance.
Ryan_Miles
Use a template
KarstenI
Another way of doing it, without migrating your networks to a template is the API:
https://developer.cisco.com/meraki/api-v1/#!update-network-wireless-ssid
Inderdeep
@Shadius : To change the password of an SSID in the Template. You need to first grab the config Template ID using (https://developer.cisco.com/meraki/api-v1/#!get-organization-config-templates)
Once you have the template for which you want the SSID password to be changed, fetch the "SSID number" ( https://developer.cisco.com/meraki/api-v1/#!get-network-wireless-ssids  )
Use the "SSID number" along with the necessary password parameters and pass them in a PUT request to update it as you need. This would update it for all the networks bound to that particular template
 https://developer.cisco.com/meraki/api-v1/#!update-network-wireless-ssid )
This is good to get the template and then change the SSID on the template via API call.
www.thenetworkdna.com
Trying doing a Google for a script.  I tried "Meraki script psk change", and found this Powershell version.
https://gist.github.com/gridironshero/517493ef8650ff6fce598856d2dc3091
I haven't used it myself or checked it.  But I bet you can find something someone has written to do this.
