Regarding Dashboard--Wireless-Access point (Usage and Contacted at) filter column
ranjankumarsgh
Hi Team,
Please help me to understand about two points on dashboard column ( Dashboard-->Wireless-->Access point) Usage and contacted at. I have filtered the dashboard column for access point for usage and contacted at.
Please clarify about below things
--Usage: Data usage is showing against each access point please let me the period of collected data
--Contacted at: Each access points showing time value in this column. Please let me how AP calculate time value at contact at column.
5 Replies 5
Usage is from 1 day. , but you can set this at the left.  to 2 hours, 1 day, 1 week etc.
contacted at: https://community.meraki.com/t5/Wireless-LAN/Contacted-at/m-p/29347
ranjankumarsgh
Thanks for your reply.
Once I download data in CSV file , the value of contacted at is coming in Numeric and i am not getting it that it is milliseconds/microseconds. My requirement is to collect all AP details last contacted with dashboard
that are seconds.  from 1970 till today. https://www.unixtimestamp.com/
would be easier to just run this https://developer.cisco.com/meraki/api-v1/#!get-organization-devices-statuses
ranjankumarsgh
Hi Thanks for understanding. I could not pull data from Link https://developer.cisco.com/meraki/api-v1/#!get-organization-devices-statuses.
I have downloaded CSV file from dashboard including Contacted at column and below value is coming. what does it mean assuming all are in Seconds and then converted into days. it is not expected to be up as per converted Days.
Contacted at
1631872018
1631871977
1631871994
1631871983
ranjankumarsgh
Thanks I got your Point
