Qualcomm chipset unable to see MR33 AP
Dixonka
We have several MR33 AP(s) configured and everything can connect except wireless cards with Qualcomm chipsets... Thoughts..??
Do you have any logging?
Can you try a ssid with basic settings.  Wpa2, 802.11r and w disabled, Dual band operation. And UNII-1 channel
The logging didn't show anything however, I did configure SSID2 (with the exact same settings as 1) and wouldn't you know it, the Qualcomm chip saw it without any issues... I disabled SSID2 and re-enabled SSID1 and the Qualcomm couldn't see the SSID again... Weirdest thing!!
Is there a difference between SSID 1 and 2 that I'm not aware of..??
