Port 1 in MR52 is POE capable ?
Philanthropist
i have situation where i want to use second port i.e. Port 1 on MR52 to provide POE power to a device and bridge its traffic to different vlan than port 0.
Any body have any idea if that possible ?
Nope:
9 Replies 9
Nope:
Philanthropist
i can use port profile to assign the port 1 to different LAN but not sure weather it will provide POE or not.
The answer is not.
Madhan_kumar_G
Following models can give power output over USB port. MR52 PoE out over Ethernet port not possible.
KarstenI
The MR36H can power a connected device with PoE:
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR36H_Datasheet
This would be an option for your use-case.
TBHPTL
Not if its another Meraki AP....
KarstenI
He certainly had mentioned this if this was the use case. But … have you tried that this really will not work?
TBHPTL
it will not
TBHPTL
https://documentation.meraki.com/MR/MR_Installation_Guides/MR36H_Installation_Guide
Same holds true for any additional LAN ports on any MR model
