PSK+ MAC Authentication Options with Meraki
Ajchan
Hi, is there any PSK+MAC authentication option available in the Meraki dashboard that can be leveraged ? Its for 150+ users and no radius/ISE services are available.
5 Replies 5
To use MAB on Meraki you will need a Radius server anyway. ISE is your best option.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Enabling_MAC-based_access_control_...
You cannot configure both at the same time.
BlakeRichardson
This is a great way of collating multiple SSID's that use PSK into a single SSID.
K2_Josh
I volunteer to be the one to say that: MAC-based authentication on Wi-Fi is not a legitimate security measure.
So as mentioned above, IPSK authentication w/o RADIUS is your best bet (with good passwords/passphrases).
