- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
New MR 31.1.2 beta firmware: Https, rogue detection and general fixes
Wireless firmware versions MR 31.1.2 changelog
Important note
- Wi-Fi 5 Wave 2 MRs support - This version and subsequent MR 31.x.x are only supported on 802.11ax (Wi-Fi 6) and newer MR models. 802.11ac Wave 2 and older products will not upgrade if they are in networks configured for MR 31.x.x versions, and thus, the new features will not be available. The bug fixes listed below will also not apply to Wi-Fi 5 Wave 2 and older MRs. (https://documentation.meraki.com/MR/Other_Topics/Cisco_Meraki_MR_Firmware_Restrictions_Overview_and_...)
Bug fixes
- General stability and performance improvements
- HTTPS redirection does not work for LSP on wired interface
- Channels missing for rogue detection
Known issues
- Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6 APs)
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So ... did pcaps on the switch, nothing, on the wired and lan side of the AP, nothing.
Once I saw a single IPv6 packet on the switch from one of the wired clients, but, just the one single lonely packet.
So I tried to change the config on the wired ports a bit, nothing.
Restarting clients, static IP, and so on, nothing.
Then, in absolute desperation and almost agony, I re-booted the AP (why would you even do such a thing.... you monster).
And I was shocked that the wired ports then worked.... shocked I tell you 🙂
I have updated the case with my findings, but Im not sure there is anything to be done now that it , apparently, works again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When will AFC support for 6 GHz be incorporated into the 31.x firmware versions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
And it immediately broke wired ports on my MR36H APs. 🙂
Case created, lets see what happens.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Luckily I had this fine, well used, adapter in my drawer 🙂
News flash, 802.11g does not feel "modern" AT ALL, in 2024 🙂
Tried to have a webex call on the thing, hot dang it a lot of poor voice and video.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
PS: And the trusted, tried and true, 802.11g adapter goes back in the drawer 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MR31.1.3 seems to "break" authentication / association on CW9164 after a while.
Different customers, and even in my lab, after the CW9164 has been online for a while a mix (when looking at the health score) of association and authentication errors seem to happen.
Eventlog on PSK/SAE networks shows EAPOL timeout, on dot1x networks not much is revealed, only what seems to be general authentication errors.
Reloading the AP fixes the problem for a while (dont know exact time).
I have not been able to do wireless packetcaptures of the problem, but it is happening on the wireless side of things.
It did not seem to be present on 31.1.2
Reverting to 30.7 and there are no problems at all, also after x time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MR APs do not seem to be affected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My CW9166 was doing the same. I've downgraded to 30.7 and it also now seems fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
"speak of the devil" ... new MR software arrived just now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hmmmm ... "just" :
Roaming-related issues with 802.11r configured SSID (Wi-Fi 6 APs)
Of course : Upgrading right now 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Was WPA3 transistion mode not supposed to fix this for me ?
This device has disabled the 6 GHz frequency band because there are no active SSIDs using WPA3 encryption.
or did I miss a "memo" ? 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hmmm the AP lies to me, my phone is connected with 6Ghz ... interesting 🙂
