Need information about MR Deployment Scenario
Bhargav
Need to know about that can we deploy AP residing in India to Office in NJ where Meraki Dashboard is deployed over cloud.
Can you Suggest Meraki AP list for office environment?
1> Create Network
2> Claim AP
3> Manually Select /Create Domain/Country
The AP needs to be turned on to change the Regulatory Domain.
8 Replies 8
NFL0NR
any of the indoor meraki ap's would should be suitable for an office environment.  Just be mindful of overall square footage.
It's very subjective, it will depend on what you need for your network, do you have any specifications?
Bhargav
I am having MR76 for warehouses at US location and at India I am willing to install MR Series APs .
Question is Can I associate MR APs at India to Meraki Dashboard which is in US?
If Yes then I can drop plan to buy 9800 WLC
Yes, you can.
You just need to change the regulatory domain:
https://documentation.meraki.com/MR/Radio_Settings/MR_Regulatory_Domains#:~:text=The%20regulatory%20....
Bhargav
So You mean to say
1> Create Network
2> Manually Select /Create Domain/Country
3> Claim AP
That's it ?
1> Create Network
2> Claim AP
AxL1971
yes you can we have multiple locations in the UK and other places in the world, under our organisation we have  networks for each of these locations.
Speedbird1
Yes you can ... We have networks in UK,EU,US and APAC under one dashboard.
From what i know the AP's will already know which regulatory domain they should be in based on  the shipping address when you buy them. If you need to change them then do as previous replies.
The only place you cant use the global meraki.com dashboard is China! where you have to setup under meraki.cn dashboard.
