Meraki teamplates
MThomas90
Meraki teamplates
Hi All,
I wanted some advise regarding templates within meraki cloud dashboard. As it stands in my environment we have a number of access points spread over 8 different locations which are currently under the same configuration Template, which means if i perform an upgrade it will will upgrade ever single AP. I wanted to see if this is best practice or would it make sense to create a configuration template for each of the locations so I can stagger the AP firmware upgrades to specific locations ? or is there a way to target only specifc APS in a template to upgrade?
Thank you for your input
MT
At that scale, I would tend to just upgrade all the APs at once.
If you are a bit nervous, and you have a lab, duplicate the current template, bind your lab network to it, and then upgrade that one first.
It will depend on the need of each one, that is, the rule has no right or wrong. In some cases, some people choose to have a single template to facilitate network management. In another, people choose to have a template for each location, but this is usually when you have some particularity for each location.
And is not possible to upgrade a specific AP on the template.
Ryan_Miles
Meraki Employee All-Star
The benefit of a template is a single configuration & administration of multiple networks (sites). Doing a template per site would provide no benefit.
