Migrate 9120AP on EWC to meraki
Nori_Mir
Hi All
I have a Cisco Embedded Wireless Controller on Catalyst Access Points running on ISO version 17.9.4.27
The AP model been registered to the EWC is C9120AXI-K
We are looking at licensing it the devices and migrating them over to Meraki. I am currently looking for some guide or advises if anyone has done this before? Thank you very much for time and attention!
2 Replies 2
rwiesmann
GreenMan
So;   your AP model cannot be converted to be fully managed directly in the Meraki Dashboard    (those APs all start CW)
And your current Wireless LAN Controller (the EWC) cannot be monitored in the Meraki Dashboard.
For cloud dashboard operations, I think you'd need to use your existing APs with a supported 9800 WLC.  Right now that would mean using a hardware Controller.   One of these:
  • C9800-L-C
  • C9800-L-F
  • C9800-40
  • C9800-80
Note tht the latter two have, very recently, had End of Sale announced for them.
If you adopted this approach, the configuration of your wireless environment would (still) lie with the (new) WLC, but you'd get a high degree of visibility from the Meraki Dashboard.
https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst/Getting_Started/Cloud_Monitoring_for_...
