Meriaki wireless access point for beginners
Indian1
Dear all,
You all might be working with Meraki access for long time. I just want to know your experience how to start from basic to advance setup & configuration for new guy.
I am new in the meraki wireless access point, have to do implement and configure many more things.
You are requested to share your knowledge where i should start my journey first   in order to learn access point configuration.
Thank you in advanced for sharing the knowledge with me.
rwiesmann
Do you knwo the learning Hub?
https://community.meraki.com/t5/Learning-Hub/ct-p/hub
Here also the documentation to AP (Installation and Configuration Guides)
https://documentation.meraki.com/MR
Here you will find all the necessary documentation to understand more about the solution.
There is also the MR quick-start guide.  It even has a video. 🙂
https://documentation.meraki.com/MR/MR_Quick_Start
Blue_Bird
You can begin with Getting Started with Meraki. Here is the link: https://documentation.meraki.com/Getting_Started_with_Meraki
