Hi @VRB ,
It's worth noting that the MR33 is has a maximum runnable firmware of MR30:
802.11ac Wave 2 and older products will only upgrade to the backup version (MR 30.7.1) if they are in networks configured for MR 31.x.x versions
If you haven't already, I would suggest opening a case with Meraki Support to investigate this issue in more detail. To submit a case in Dashboard:
- Log-in to Dashboard.
- Navigate to "?" (top-right on green ribbon) > Get help & cases.
- Select a Product or Platform tile related to the issue you need help with
- Select the device to be associated with the case. You can use the search bar or any of the dropdown filters to find your device based on:
- Device Name
- Product / Platform Category
- Network
- Mac Address
- Model Number
- Serial Number
5. Select if the issue relates to an existing case or a new one, and then enter a description. A list of open cases is available by clicking on the Case dropdown field. If creating a new case, select the Severity Level that best describes the business impact you are facing:
- Severity 1: Critical impact on the customer’s business operations. Cisco’s hardware, software, or as a service product is down.
- Severity 2: Substantial impact on customer’s business operations. Cisco hardware, software, or as a service product is degraded.
- Severity 3: Minimal impact on customer’s business operations. Cisco hardware, software, or as a service product is partially degraded.
- Severity 4: No impact on customer’s business operations. The customer requests information about features, implementation, or configuration for Cisco’s hardware, software, or as a service product.
6. Select a preferred contact option (available based on the severity selected)
7. After you have submitted the case, you will see a Summary confirmation and the severity level you have assigned on the case:
You will receive a confirmation email, or or you will receive a call when using Call Me Now. You can update the case if needed by replying to that email, or visiting the "?" > Get help & cases > View full case history page in Dashboard.
The more details you can provide when opening the case, the faster the Support team can begin diagnosing your issue. This could include;
- The LED status of the AP when it is 'hung' (solid amber, flashing blue, rainbow, off etc.)
- The Support Data Bundle taken from the AP
- A packet capture taken on the switch port the AP is connected to
