Meraki gr60
Stanislavm
Meraki gr60
good day, I bought a used meraki go gr60 and I can't add it to my topology at home because another organization claimed this device. how can i solve it
rwiesmann
Best ist to just call Meraki support
@rwiesmann  I had the same problem months ago, but the Meraki support can't unclain the device, the best way is ask the saller to unclain It for you.
@Stanislavm you need the seller to unclaim it, or give you a refund
BlakeRichardson
I would avoid buying second hand devices unless you can be shown in person thats its been unclaimed even then its still risky.
