Meraki WiFi Authentication with Azure AD
Damith_Darshana
Hi Guys,
We're in the process of moving from our on-premises AD to Azure AD. Our current setup relies on RADIUS authentication for our Wi-Fi network, which is integrated with our AD.
We're searching cost-effective options for maintaining this authentication system without deploying a RADIUS server like Cisco ISE or Azure AD DS with LDAP.
Is there any method to do this directly using Azure AD or has anyone found a good solution for this?
I'd appreciate any insights or suggestions you might have.
There is no "great" solution.
If you buy Meraki Systems manager licences, you can use something like Trusted Access.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Trusted_Access_for_Se...
If you use Intune you can use something like Cloud PKI to do certificate based authentication.
https://learn.microsoft.com/en-us/mem/intune/protect/microsoft-cloud-pki-overview
You could also consider using Azure/Entra AD DS.
https://apicli.com/2021/12/13/meraki-mr-802-1x-with-azure-active-directory/
There are also third party solutions like Splash Access.
https://www.splashaccess.com/azure-active-directory-authenticated-wi-fi/
TRS22
Hi Damith,
We too are in the same situation.   Checking back to see which direction you went and how that design is working.
Tis
