Reporting on Sponsored Guest splash Logins
JamesBalchin
Hi all,
Is it possible to pull a report on logins that have used the Sponsored Splash Login?
I am aware that I am able to see the details I required [Who authorised the login and expiry] on a per client basis.
But that is quite a slow and painful way to gather info for all clients.
2 Replies 2
Unfortunately,  Meraki does not currently support this feature. You can make a request for a new feature.
Maybe the Splash Access can provide what you are looking for.
https://www.splashaccess.com/
