Meraki Switch networking questions
Keith_Li
Dear All,
            I got a question on some networking issue on meraki switches setup,  below are the SSIDs that i use in one of the network profile in meraki dashboard, for switch port 7 & 8 i can specifically assigned with allowed vlan 113,213-214 rather than vlan all ? as previously i configured as vlan all, so for this time i want to put specific vlan rather than vlan all, is this look correct ?  any help would be appreicated
ssid: Guest (vlan 103 IP segment 192.168.1.0/24)
ssid: John hardy (vlan 104 IP Segment 192.168.2.0/24)
ssid: Internal (no vlan tag)
port 1 - 6 configured as trunk native vlan 123  (so AP will be obtained IP 10.1.0.0/24)
port 7      < connecting to internet circuit for ssid "Guest & John hardy"
trunk
native vlan 1
allowed vlans 123,103-104
port 8       < connecting to SD WAN for ssid "Internal" with raduis
trunk
native vlan 1
meraki switches itself will be assigned with static IP 10.1.0.100
Piaakit
BlakeRichardson
VLAN tagging is comma separated i.e. 2,4,6,8 and dashes for a range 2-8. You can do a mixture of both i.e. 2,4,6,8,100-110
Brash
Assuming the AP's are connected to port 7 and 8, then yes the config you have matches the tagging you're doing on the SSID's. The AP's (unless configured otherwise) will pick up IP's in VLAN 1 for their management connection.
One thing to be aware of is that by not VLAN tagging the "internal" SSID, any client connecting to it will use VLAN 1.
Keith_Li
actually AP are connecting to port 1 to 6 with trunk native vlan 123 with allowed vlan all
You just can't do it as you should, whenever possible, the recommendation is that you only configure the VLANs that will actually be used on the Trunk port.
