Any update on this from HP/Meraki?
We are in the same exact boat. So far we have isolated the issue to the following Realtek WLAN Cards so far: RTL8822CE and RTL8822BE. Current workaround is to install the following older drivers and this works fine for connectivity but not sure if it has other side affects. If we install the latest driver from HP, Windows Update the problem comes back.
- o RTL8822CE - 2024.0.8.134, driver date: 12/1/2021
- o RTL8822BE - 2024.0.8.133, driver date: 8/19/2021
So far we have tested the following AX disabled, 12mbps bit rate set, radio power adjustments, channel adjustments etc, max performance settings for the WLAN adapter. We have not tried disabling 802.11k yet, but does not look like that works from other users feedback but we will try it anyway. We have an active support ticket with Meraki.
if we don't use the drivers noted above, what we notice in the Meraki logs in the request "client has left ap" messages every few seconds and also, not sure if this is related is that even though we are not using 802.1x, we are seeing 802.1x authentication related events on the WiFi 6 access points. When we have the problem the packet loss is about 8% to 12%. Intermittently as well the client would chose to connect to distant access points.
once we install the older drivers then everything seems to go back to normal, no packet loss, constantly connect to nearest access point.
Thanks.
