Max lenght for a MA-ANT-25 antenna
MA-ANT-25
Hi
The MA-ANT-25 antenna is provided with a 12 inches connector  lenght.
Do you know if longer connector exists and what is the maximun lenght ?
Eric
The datasheet does not mention longer cables available directly from Meraki. You can use compatible extension cables to achieve the desired length.
Please note that when using extension cables, it is important to consider the potential signal loss that can occur with longer cables.
To add to this, you generally want to use lower-loss cable as you add length to maintain the overall gain (or at least limit the loss of gain).
TBHPTL
for 15-20ft of LMR400 you are looking at ~2-3dB of loss with N-Connectors.
Why do you want a longer antenna cable? Why not move the AP to accommodate your antenna location?
