Mac authentication for devices that cannot login
networks2
How to configure authentication for wifi devices that are not able to login by itself.
Use a local user and password database in meraki dashboards? no radius.
Devices using its mac address as login.
Devices using its mac address as password.
Thanks for any help
5 Replies 5
networks2
Thanks for your reply.
networks2
Thanks for your reply, PhilipDAth
These devices only have the option of connecting to an SSID, then somehow i need to allow (default is to block anything on the SSID IOTDevices) them via its mac address.
They are not capable to have pre-shared/passphrase settings set.
Needs to work like this, i guess.
1) I need to manually add their mac address somewhere locally (or Meraki picks mac up connecting to the SSID, then allow in a policy etc).
2) IOT device connects to SSID IOTDevices.
3) Merkai looks up IOT device in a mac database.
4) Merkai then allows IOT device to connect.
Any ideas??
The @PhilipDAth's idea is better.
