Mac Device not connecting to SSID PSK Group Policy
JacobTank
We recently setup a new SSID without Radius using PSKs to assign Group Policies. Works as expected. When trying to replicate at another location, Apple Devices are unable to connect. Swap to a single PSK and everything works fine. When multiple PSKs are setup the WiFi indicator spins and the users is repeatedly prompted to enter a password. Have tested on M2 and Intel macs.
Have you checked the log messages? Have you reviewed the group policy?
Group policies are only used to assign VLANs, nothing seems off with them. Event logs shows disassociation and deauthorization for the mac around those timeframes, but I didn't check in real time so no way of knowing if my issue triggered the log.
I suggest you to perform a packet capture and open a case with Meraki support.
GreenMan
Have you compared MR hardware models and firmware versions between the Networks?  You'll probably want to raise a case with Meraki Support
