FW 29.4 and Client Balancing
AxL1971
I see FW 29.4 which is in beta has a new feature client balancing
https://documentation.meraki.com/MR/Other_Topics/Client_Balancing#Client_Balancing_Behavior_Prior_to...
Anyone deployed this and give feedback on this feature
Due to the firmware being beta I am unable to deploy it, any news on when this will become a stable release
1 Reply 1
GreenMan
Just to be clear - Client Balancing has been available since firmware 25.x.    The way it works though has changed under 29.x    Both iterations are described here:
r29 becoming stable will take some time (as yet unknown) - as it will need to go through successful Release Candidate (RC) phase first.   If you have a test/non-critical environment at all, where you can test 29 now/soon, it will both help refine feature operations and help uncover any issues (you can work with Meraki Support on any issues seen with firmware, even if they are on a Beta version.).   Wider adoption / testing of new firmware always helps speed up progress towards Stable status.
