MR76 antennas
CraigAP
MR76 antennas
We are installing MR86 with the Cisco AIR-ANT2513P4M for pallet racking and it works very well, however the client has a number of sites with shorter aisles that this antenna panel would be a massive overkill, not to mention cost!
Are there any alternative panels that support dual band but with a lower gain?
That's correct. This blog shows a couple of photos of the MR86 with the MA-ANT-25 antennas for reference.
Ryan / SE - Networking
Ryan_Miles
The MR86 also supports the MA-ANT-25 and MA-ANT-27.
https://meraki.cisco.com/product-collateral/ma-ant-25-datasheet/?file
https://meraki.cisco.com/product-collateral/dual-band-sector-antenna-datasheet/?file
Thnaks Ryan. Are these antennas used in pairs due to only having 2 connections?
Thanks Ryan, we have a few on order now to try out.
