MR76 - Connected and disconnect
npnitin
we are using MR 76 AP in our environment.
We are facing the below issue:
IoT devices connected to AP for less than 1 min then move to another AP and stay there for 1 min after that disconnect and then connect to the other AP.
AP to AP distance in 12-17 meter.
Please assist me in this regard
GreenMan
Meraki Alumni (Retired)
Are the devices communicating via bluetooth or WiFi?   To my knowledge both of these technologies leave any roaming decisions to the client device itself  (so check documentation and config / firmware options for those)    If it's WiFi, check to see if there are any AutoRF-related reconfigs of the APs, at the times in question - changing channels or Tx power, that might affect the client's decisions.   You could consider fixing those WiFi parameters through an RF Profile:    https://documentation.meraki.com/MR/Radio_Settings/Manual_Channel_Selection%2C_Transmit_Power_Adjust...
EJN
I don't have the answer, but see if this helps:
https://documentation.meraki.com/MR/Bluetooth/Bluetooth_Low_Energy_(BLE)
Esteban J Nunez
School and Church
K-12 Education
GreenMan
Is this causing a problem?  Clients should be able to roam seamlessly.
