MR72 with A POE INJECTOR and flashing Blue
Justin
Hi I have a MR72 and when I plug it into the wired network everything is great. Now i need to to be wireless so when I plug it into a POE injector (no wired network connectivity just using the POE injector for power, just wanting to use wireless) It just flashes blue. I have created the primary wireless profile and a backup. I made sure to validate the SSID and PWD. What am I doing wrong?
Justin
Ok after asking for some help all that was needed was to reapply my SSID and PSK. Now it works. Not sure what happened there. It just didnt take the first time.
Inderdeep
@Justin : After powering on, your AP will download the latest software. This may take up to an hour, depending on the Internet connection speed. While upgrading, the AP's power LED will flash blue. Once the AP has checked into the dashboard, the LED will turn green.
Check this guide below
https://documentation.meraki.com/MR/MR_Quick_Start
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Justin
Inderdeep
Oh Ok , Hope the issue resolved now, Good Luck !
