MR53 upgrade to MR57 client connectivity issue
hillster
Hi Can you possible assist I have a strange issue where as we have 2 builds of laptops onsite
We have recently  refreshed our old access points from Meraki MR 53 to Meraki MR 57  everything was working fine with MR 53
But we are now encountering an issue with our older workstations will now not connect
802.1X with custom RADIUS
PSK (WPA2)
Sign-on method
None
Bandwidth limit
unlimited
Client IP assignment
Local LAN
Clients blocked from using LAN
no
Wired clients are part of Wi-Fi network
no
VLAN tag
10
VPN
Disabled
Client  connects via SSID  and .1X  obtains a valid IP address from DHCP server on vlan 10  as per above
however we cannot hit its own Gateway
Newer build laptops are working fine.
All was working on MR 53 so no settings have changed.
Any ideas what the issue is to diagnose ?
7 Replies 7
GreenMan
My first guess on this would be to look to update the WLAN driver(s) for your laptops.   Go to the site for the wifi chip manufacturer, rather than just relying on the Windows updates.
hillster
thanks for reply - I have already tried this update the WLAN drivers...but unfortunately the issue is still the same .... Just to reiterate the older laptops worked fine on MR 53 set up so nothing changed on client
just doesn't make any sense.
No usefull logging in the event log regarding this client?
Maybe try disable .ax in the wifi profile.
Do the laptops have Intel chipsets for the wireless, we had a ton of issues with older drivers on 8260 and 9260 chipsets in particular when moving to Wi-Fi 6.  It sounds like you are seeing the same issue.  If they are Intel, what driver version are the troublesome laptops running?
GreenMan
If you didn't already;   raise a case with Meraki Support...
hillster
I have raised a case direct with Meraki - I have updated all the drivers etc to latest but still seeing issue where as cant ping GW this is  only on the older laptops - all the newer build laptops are working
@hillster do the drivers have a version number?
