MR36 to Cloud without MX?
BWSI
To manage a set of MR36s through Meraki is it a requirement to connect through a MX--- firewall or can the A/Ps connect through a 3rd party firewall as well?
Please advise
Ryan_Miles
Meraki Employee All-Star
You don't need a MX. Meraki APs can connect to anything.
5 Replies 5
Ryan_Miles
BWSI
So the only requirement is that the A/Ps are registered in Meraki, correct?
Ryan_Miles
Yes
Just in case the obvious has been missed, the MR36s still require power.  Normally this is done via PoE.
BlakeRichardson
@BWSI All Meraki gear with the exception of sensors will work with other routers / switches etc. This is one of the beenfits of Meraki, you can pick and choose.
