MR AP compatibility with MR42
atorres
I have MR42 APs which are EOL and their replacement is the MR44. We cannot get the MR44 for at least a year, so I am looking at the MR36 which is in stock. Can the MR36 and MR42 work together? This is for a small ~20 users office space. APs will be spread out through 2 floors.
Thank you!
AT
BrandonS
Yes, pretty much any MR's can work together.  The only exceptions might be for fairly complex, special requirements and it does not sound like you have those.
BrandonS
atorres
No, not complex. 2 APs currently and extending with 2 more to floor below.
Thank you!
I'd go with the MR36.
The only issue you are likely to run into is with the firmware on clients.  The MR36 is WiFi6, while the MR42 is WiFi5.  Let's say you are a WiFi6 client.  The WiFi6 AP has a weaker signal (further away) than the WiFi5 AP, but you really want to stay connected using WiFi6 because you are also using WiFi6.
Some clients aren't as smart as others at choosing which AP to connect to.
@atorres I'm sure you know, but just to clarify, the MR42 is end of sale and not end of life.  The latest 28.6 firmware supports both it and the newer WiFi6 models.
