MR28/MR36 BSSID Calculation
Spaz
Hey guys,
There is a flow in my company that we need to calculate BSSIDs, and we were following this guide (which is no longer up to date).
We encountered a situation with thousands of MR28/MR36 access points (not in the guide), to get the BSSIDs, we have to query the wireless/status endpoint many times, which causes a very slow flow.
Can someone advise how we can calculate the MR28/MR36 BSSID?
Thank you.
Ryan_Miles
Meraki Employee All-Star
Here are a MR28 and MR36. I think my offsets are correct keeping in mind I woke up less than an hour ago and have had maybe 3 sips of coffee. Others perhaps can check my math and hex skills.
MR28
Base MACe4:55:a8
 2.4 GHz1st octet offset5 GHz1st octet offset3rd octet offset
SSID 1e4:55:a8no changee6:55:b8+ 0x02+ 0x10
SSID 2e2:55:a8- 0x02e2:55:b8- 0x02+ 0x10
SSID 3ee:55:a8+ 0x0Aee:55:b8+ 0x0A+ 0x10
SSID 4ea:55:a8+ 0x06ea:55:b8+ 0x06+ 0x10
SSID 5f6:55:a8+ 0x12f6:55:b8+ 0x12+ 0x10
SSID 6f2:55:a8+ 0x0Ef2:55:b8+ 0x0E+ 0x10
SSID 7fe:55:a8+ 0x1Afe:55:b8+ 0x1A+ 0x10
SSID 8fa:55:a8+ 0x16fa:55:b8+ 0x16+ 0x10
SSID 9c6:55:a8- 0x1Ec6:55:b8- 0x1E+ 0x10
SSID 10c2:55:a8- 0x22c2:55:b8- 0x22+ 0x10
SSID 11ce:55:a8- 0x16ce:55:b8- 0x16+ 0x10
SSID 12ca:55:a8- 0x1Aca:55:b8- 0x1A+ 0x10
SSID 13d6:55:a8- 0x0Ed6:55:b8- 0x0E+ 0x10
SSID 14d2:55:a8- 0x12d2:55:b8- 0x12+ 0x10
SSID 15de:55:a8- 0x06de:55:b8- 0x06+ 0x10
MR36
Base MAC68:3a:1e
SSID 168:3a:1eno change6a:3a:0e+ 0x02- 0x10
SSID 26e:3a:1e+ 0x066e:3a:0e+ 0x06- 0x10
SSID 362:3a:1e- 0x0662:3a:0e- 0x06- 0x10
SSID 466:3a:1e- 0x0266:3a:0e- 0x02- 0x10
SSID 57a:3a:1e+ 0x127a:3a:0e+ 0x12- 0x10
SSID 67e:3a:1e+ 0x167e:3a:0e+ 0x16- 0x10
SSID 772:3a:1e+ 0x0A72:3a:0e+ 0x0A- 0x10
SSID 876:3a:1e+ 0x0E76:3a:0e+ 0x0E- 0x10
SSID 94a:3a:1e- 0x1E4a:3a:0e- 0x1E- 0x10
SSID 104e:3a:1e- 0x1A4e:3a:0e- 0x1A- 0x10
SSID 1142:3a:1e- 0x2642:3a:0e- 0x26- 0x10
SSID 1246:3a:1e- 0x2246:3a:0e- 0x22- 0x10
SSID 135a:3a:1e- 0x0E5a:3a:0e- 0x0E- 0x10
SSID 145e:3a:1e- 0x0A5e:3a:0e- 0x0A- 0x10
SSID 1552:3a:1e- 0x1652:3a:0e- 0x16- 0x10
11 Replies 11
KarstenI
Support should be able to help here. But the Documentation should also be updated @Hannah-C
I think the chances are very slim - but by chance, does the org-wide call return the information?
https://developer.cisco.com/meraki/api-v1/get-organization-devices-statuses/
Spaz
From the API response example, I see that they are not bringing the BSSIDs, am I wrong?
Ryan_Miles
The doc was meant to help figure out the BSSIDs before the information became available in dashboard and via the API several years ago.
Because of this the article says "No new BSSID values will be added to this article moving forward".
Pulling the info from dashboard or API shows the patterns used and one can extrapolate from there to apply to any AP base MAC. Bearing in mind the pattern can be different per model and depends on how many radios there are (2 or 3).
Spaz
Hi @Ryan_Miles , thanks for the answer,
To be honest, I think it will be complex to reverse engineer it; I need a lot of examples, and I'm not sure I will do that 100% right.
I greatly appreciate your expertise in this field and your willingness to assist.
Is there any option to get a guide or something?
Thank you,
Emanuel
Spaz
I got some insights (specifically on MR28)
I'm posting it as a picture because it keeps deleting my message because of the table.
Ryan_Miles
MR28
Base MACe4:55:a8
MR36
Base MAC68:3a:1e
KarstenI
Oh, and I realize that the BSSID Details in the dashboard are not correct. I am connected to a BSSID ...63:07:ee:dd, but based on the dashboard it should be ...63:07:ee:d0.
Isn't it simpler to use a Wifi spectrum analyzer?
Have you checked this discussion?
https://community.meraki.com/t5/Wireless/Meraki-MR-BSSID-MAC-Calculator/m-p/32358#M5129
Spaz
Yep, he doesn't have MR28.
