MR - 24 to deploy - HowTo setup MS NPS 'subnet allow' , instead of adding 1 AP at a time in Radius
EdQ
good day all, i feel i am so close but still missing a key point.
in deploying new-to-me MR-wireless, my current system , i only had to add the Controllers, not the APs.
so , in MR deployment, i have added 2 MR APs as client, but 1) they are dhcp, so can change IP (yes, will do Reservations) and 2) i have 22 more to add, and would rather do 'add subnet' approach inside MS NPS wizard for Network Policy
it seems like only the directly-added APs are the ones authenticating though
any docs or pointers on the complete process for NPS setup for 10.x.x.0/24 subnet allow for Auth ?
thanks !
Ed
2 Replies 2
Mloraditch
https://learn.microsoft.com/en-us/windows-server/networking/technologies/nps/nps-radius-clients-conf...
That's all you should have to do, it's just a client with a subnet/ip range vs a single IP, and you reference that client in your policy
EdQ
ok, thnx, just put in place. will see if my Logs clean-up with units i have not explicity entered, as doing good auth requests. and will reply here after.
