MAC address authentication with pre-shared key
rmothers
Has anyone set up MAC authentication with a pre-share key? I only see MAC authentication or Password not a selection for both.
Thanks in advanced.
Rodney
5 Replies 5
Instead of it, why don't you use a iPSK without Radius server?
https://documentation.meraki.com/MR/Encryption_and_Authentication/Wireless_Encryption_and_Authentica...
BlakeRichardson
@rmothers MAC Auth with PSK is not a supported option sorry. Why it's not supported I have no idea but I know other vendors support it. Yes MAC can be spoofed but IMO it should be up to the network admin to choose work works best for them.
KarstenI
iPSK with RADIUS is basically PSK with Mac filtering. You just have to return a Tunnel-Password.
BlakeRichardson
Yes but I am thinking about those small businesses who might not have a radius server. If you can enable MAC filtering on a MS switch port then why isn't it supported on wireless?
KarstenI
That's a very good question. Would be a perfect task for "a cloud".
