MAC Authentication - how to dynamically control Bandwidth rate per client?
Alexs20
I there any way to control Bandwidth rate dynamically using RADIUS response in  "MAC-based access control" mode?
I know how to do that via polices, but i need to control it dynamically, per authentication, something similar to that:
WISPr-Bandwidth-Max-Up := 100000
WISPr-Bandwidth-Max-Down := 100000
Thanks.
6 Replies 6
Unfortunately not.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
GreenMan
I would look at assigning Meraki Group Policies using RADIUS attributes:  https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
and configure Traffic shaping within the policy
Alexs20
yeah, looks like this is the only way
Yes.  The attributes to use are:
Maximum-Data-Rate-Upstream
Maximum-Data-Rate-Downstream
You can find all the attributes allowed in this document.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_captive_portal.pdf
Alexs20
unfortunate it doesn't work with either "MAC-based access control" nor "Identity PSK with RADIUS"
looks like this is only for Sign-on Splash
just tested
Bummer!  Then your only choice is group policies.
