COA destination IP
Alexs20
COA destination IP
Assuming that I have one AP connected to Meraki cloud, with "MAC-based access control (no encryption)" security mode enabled.
I also have "RADIUS CoA support" option enabled.
What is the destination IP for CoA messages? Is it the same as Meraki console FQDN?
5 Replies 5
I don't know the answer - but surely it would be it would be the source of the original RADIUS request - the AP itself.
That means that I cannot use external RADIUS server (means hosted in internet) as AP sits behind the firewall.
Hmmm, ok, thanks.
Brash
Similar to @PhilipDAth, I also don't know the answer but I think you're right.
CoA would require the RADIUS server sending a request to the AP which isn't really possible without an inbound NAT or proxy.
I initially thought you could look at using the Meraki RADIUS proxy but it doesn't support CoA.
Alexs20
Looks like I need a little more help.
So, I am trying to talk to AP using radclient utility
my command is
echo '
Calling-Station-Id = "<MAC redacted>"
NAS-IP-Address = 192.168.2.224
Filter-Id = "PASS"
Event-Timestamp = "1692895863"
cisco-avpair="subscriber:command=reauthenticate"
cisco-avpair="subscriber:reauthenticate-type=rerun"
' | radclient -x 192.168.2.224:3799 coa <secret redacted>
But there is nothing coming back.
192.168.2.224 - is IP of my AP and this is what i see in Access-Request message when connecting to SSID
Any ideas?
Alexs20
oh, NM, I found the problem. I had to add my PC IP into the list of radius servers
