Doing an internal lookup I think I found your case and org. SSID is iHeart? Logs are full of RADIUS and EAPoL timeouts. Assume the RADIUS server is reached over WAN/VPN? Maybe there's some latency being encountered here and timers need to be adjusted? Also, doing some traceroutes from AP to your RADIUS IPs and I don't think I've ever seen 169.254.x.x's show up in a traceroute. Perhaps that's expected I just don't think I've ever seen that before in 25 years of running traceroutes.
Are there any issues on the guest SSID which appears to be using a PSK.
Also, looks like Support rolled your MR33s back to 27.x. Just be aware the MT sensor you have will no longer talk to any of the 33s as that needs 28.x. The MT can still talk to your lone MR36 and the MVs at the site.
Ryan If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
