Individual AP upgrade
Noah014
Hi everyone! Is it possible to, individually, upgrade an AP? I mean, select the network and then select each AP I want to upgrade?
Thanks  🙂
As @kn-kimura has said, you can only upgrade whole networks, not an individual AP.
If you want to do a test, clone the network, move the AP into it, and then upgrade that network.
8 Replies 8
DarrenOC
Hi @Noah014
In the meraki dashboard, if you go to the access point in question under "wireless" and scroll to the bottom of the access point page, you can select to update that single AP's firmware.
DarrenOC
Hmmm, ignore that! You could once do that.
what about creating a new Network, move an AP into it and upgrade the firmware from there?
kn-kimura
Hi, Meraki has a specific firmware version for each network.
It is not possible to fix the version of the firmware for each device.
NGleich
Hi everyone,
Can't you just go to Organization's Tab and select "Firmware Upgrades --> All networks tab" and then select the relevant devices you want to upgrade ?
All my devices are up to date so i can't test it right now but at least i am able to select them one at a time and schedule an upgrade for each of the selected devices.
Maybe give it a try 🙂
Kind Regards
Niklas
@NGleich i only see networks in that list.
NGleich
Oh i see, you're right. My mistake, sorry 😞
Noah014
Thanks everyone :). I'll do a network and just move the AP i want to upgrade
