ISE certificate MR36 and MR44
Gunnel
Hi all!
We have a networks mixed with Cisco Classic Switches and Meraki APs. In one of them there are issues with one of the SSIDs. One C2960 switch connected to MR44 APs and one C9200 connected to MR36 APs(both with version 30.6). It is not possible for computers that are not company owned and for phones(regardless of owner) to log in to the main SSID, they do fine on our guest SSID however. We suspect troubles with the ISE certificate. Usually when you log on to our main SSID your phone would ask you if you trust this certificate, this does no longer happen on our main SSID in this particular network. It used to work well. The log sometimes complain about CoA, sometimes about DHCP and sometimes abour Radius. Any ideas?
2 Replies 2
Your SSID is probably configured to authenticate using a certificate, so only machines that are in the domain can authenticate, as they have the certificate installed on the machine.
To resolve this issue, you need to install the certificate on devices that are not part of the domain manually.
I don't know if you have mastery of ISE, but it would be interesting to request support from someone who has good knowledge of ISE.
It's not complex at all, but you need to have a minimum of knowledge.
It works fine in all of our other subnets so it can't be that.
When you connect to WiFi for the first time it asks you to accept the certificate but on this particular subnet that stopped happening a few weeks ago. I've looked in the ISE log and it complains about the client not responding.
