Pointing Meraki access points to Forescout captive portal
houseofblues
Hello All,
I am relatively new to Meraki access points and I need to set up a guest ssid that points to a Forescout captive portal where users will enter their email address and other information to get a token so they can log into the guest network.
Any help would be greatly appreciated. Has anyone else succesfully done this?
Thanks,
houseofblues
2 Replies 2
I did a quick Google and didn't find anything for Forescout.
I'd hit them up for a Meraki setup guide.
AWQAFINV
Hi Mr. Philip,
Good day! Hope you are doing well.
We appreciate your support if there is any solution regarding redirect guest to Forescout Guest portal registration on associated Meraki AP.
Currently, we are facing same issue and couldn't found a solution for that.
