Hi, I presently installed a Catalyst AP, and IP address stays as 10.10.1.1 (via DHCP) it only registers to the cloud if the VLAN is changed on the switch port, another AP was set with the same configuration but on another network and it comes up with IP address 192.168.10.10 and it registered fine. SSID is set in Bridge.
Regards
