I am trying to get a laptop connected to our company wifi. It refuses to connect to it although other devices are able to connect without a problem. I am able to see the device connect and it has a 0.0.0.0 address but on the laptop itself it does not successfully connect. This is happening two laptops at two different branches. Both laptop and users are allowed to access the wifi. I've reinstalled wifi drivers on the laptops. When I check the event logs on meraki I see the device associate then disassociate just a bunch of logs of it doing that.
Is the notebook definately configured to use DHCP on the Wifi adaptor?
Are you using a non-standard minimum bit rate on the SSID? I tend to use 12Mb/s myself as it disabled old 802.11b yet retains high compatibility with most other devices.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da4c4f94d2400","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da4c4f94d2400_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da4c4f94d2400_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da4c4f94d2400_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6da4c4f15052f0","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
