How to see wireless clients connected to specific SSIDs.
jvanscoyk
I am trying to display wireless clients that are connected to a specific SSID in a network in the dashboard.
I need to generate a report so that IT services in that area can find the devices and move them to another SSID.
I am not seeing the ability to display those clients though I may be overlooking something.
6 Replies 6
behind clients it says: all
You can change that to filter on ssid
jvanscoyk
I see no filter capabilities on SSID.
I can add a Recent SSID column to the display but I am unable to filter on just an SSID.Screenshot 2023-10-16 at 10.51.47 AM.png
RaphaelL
Higher on the page:
RaphaelL
Like ww said or if you want an Org overview you can go to Organization -> Summary report and select your time range and your SSID and you will get a nice report that is  IT management frendly 🙂
but you won't have client details ( MAC , name , IP and so on  )
jvanscoyk
This has very useful information on it though if I export it to Excel, all I get is the number of clients connected to each SSID. Not useful at all for what I need. I apologize if I am missing something but this is useless for what I need. The tabs on the excel spreadsheet do not tell you what SSID the clients are connected to. I don't understand how this is not something I'd want to filter on.The filter works on the dashboard but not when you export to excel.
RaphaelL
That page is named Summary report, it is only reporting the usage / utilization of your SSIDs. You won't get client details ( which client was connected to X AP or Y SSID ) , you will need to go to the network as shown by ww
