How to export historical data (send/recieve) per device?
SCPHUB
Just browsing
Best regards,
1 Reply 1
If you mean something like bitrate versus time - there is no export function like that in the Dashboard.  It would be possible to extract some data using the API.
https://developer.cisco.com/meraki/api-v1/get-network-clients-bandwidth-usage-history/
