MR36H - Can it act as workgroup bridge
CarlT
Hi All
We have a Meraki MR36H that we want to plug a printer and pc into the wired ports, this should then mesh to the nearest AP.
Some colleagues tried this yesterday and apparently it did not work.
Should this functionality work?
Many thanks
2 Replies 2
This is supposed to work.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Port_Profiles
Mark_S
Hi CarlT,
As detailed by alemabrahao above, this indeed should work.
If you have not already, I would recommend raising a case with Meraki support so they can assist with troubleshooting this issue to help determine why this was not working at the first attempt.
Details on how to raise a case through dashboard or to call the support line can be found within the 'Get help & cases' page which is accessible in the ? icon menu in dashboard.
