How pass the radius server test (for a mac adress ssid experiment)
CarOneAdmin
Dear All,
i make an ssid with mac adress authentication for an experiment
but now i dont know how pass the radius server test
how i can know my host & port? on the secret part i can use any word or an special key?
this link help me but i dont believe much on him https://check-host.net/
sorry for my basic aknowledge, this are my first steps on meraki administration.
Thanks!
AjitKumar
Hi
For MAC Based Authentication you need to have an In-house Radius Server.
Meraki does not offer a Radius Server with MAC Based Authentication.
Once you have your own independent Radius Server either on Windows or Linux. You may connect the same to Meraki SSID.
Your page may look like below with the IP address and secret key configured on your Radius.
Incase you want to use Meraki Radius server which will do only Username based Authentication.
You need to create User Account and Authorize them with the time the access is allowed for. You can create Users under
Network-wide -> Users
However prior to this you need to associate your SSID with Meraki Radius. You can do this under
Wireless -> Access control
If required you may also customize Splash page (Landing / Welcome / Captive page)
Wireless-> Splash page
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
6 Replies 6
MRCUR
It sounds like you don't have a RADIUS server set up if you don't know the host/port/secret. You'll need to run your own RADIUS server such as NPS on Windows Server. See here for documentation from Meraki: https://documentation.meraki.com/MR/Encryption_and_Authentication/MAC-Based_Access_Control_Using_Mic...
You could alternatively use Meraki hosted RADIUS if you are okay with doing user auth instead of MAC based auth. Keep in mind that MAC's are very easy to spoof.
MRCUR | CMNO #12
CarOneAdmin
Thanks,
Yes i dont have a radius server, i only have a hosted meraki wireless adm.
Yes how i can configurate that? its only for a test to my boss
Regards!
MRCUR
did you setup your own radius server?
CarOneAdmin
Not yet, really i dont know how to do that.
Some of help are benn appreciated.
Thanks!
AjitKumar
Hi
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
