How do I configure MR 33 in repeater mode ?
AK77
Team, I already have a broadband router from my service provider, which is on the ground floor
I want to user MR33 on as an extension of wifi to 2nd floor,
how do I configure MR33 in repeater mode ?
ConnorL
It doesn't need any configuration. Give it power and make sure it's claimed into the correct network, in due time you should see it come online as a repeater.
For more info, see: https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Using_a_Cisco_Meraki_Access_Point...
Only works with meraki products  2x MR.
Not with just any router
You can use it as extension using a utp  cable  to your corrent (wifi)router, put mr ssid in bridge mode, and use the same ssid as you router.
ConnorL
Ah good catch! Shows I shouldn't skim read a post. Yes, MR's can only mesh with other MRs. You *cannot* configure an MR to repeat any non-MR networks, this includes MX with Wireless.
