How do I compose a report of clients connecting to 2.4ghz?
RyanDonaldson
i have been trying to compose a report of clients connecting to the 2.4 ghz Wifi via the event log, i have been able to get the 802.11 association but that is pulling the 5 ghz as well, I'd rather not have to scroll through thousands of entries to find the ones I'm looking for is there any way to do this?
Check it out.
Re: Report on 2.4Ghz clients - The Meraki Community
Solved: Reporting on clients connecting at 2.4GHz - The Meraki Community
ammahend
other option is also running a client report in google sheet using Meraki API, use this link here, then you can filter client by radio 0 or 1 for 2.4 or 5Ghz
https://developer.cisco.com/meraki/build/meraki-dashboard-reports-with-google-sheets/
Main10ence
@RyanDonaldson@ammahend is on the money! Meraki's Google Speadsheets plug in is the way to go here! You can pull and filter the results in a spreadsheet.
Not only that, you will find more useful reports within the plug-in that will help in the future; I'm sure of it!
.ılı.ılı. Cisco Meraki
Network Support Engineer
"The future favors the bold."
AxL1971
I use API call for this, The API call I make extracts clients connected to SSID or Radio spectrum, writes to a back end SQL database and then I can report on the data either using Power BI or Excel
