We have recently configured a SSID using 802.1X and 802.11r is enabled.
Upon looking at all the connection logs and keeping an eye on the Wireless Health , I have been able to observe that we are now having lots of events of that type :
auth_mode='wpa2-802.1x' ft='1' reason='invalid_pmkid' radio='1' vap='0' channel='40' rssi='36'
We are using MR36 and the firmware version tested are 27.7.1 and 28.5.
Most of these logs are from mobile IOS devices running IOS 12+++. Dashboard says the devices are 802.11r capable.
1- Do you think that 802.11r in adaptive mode will help ?
2- I have noticed that 28.6 seems to have fixed issues with pmk , I might try that one.
Has anyone come across that ?
Thanks ,
Bumping my thread. Any Wifi guru here ?
28.6 didn't ''fix'' this issue. Some phones are OK , some are plagued with that error
Thanks ,
Have you tried running 802.11r in adaptive mode as originally proposed? This was something created between Cisco & Apple so iPhones should support that with no issues
Currently testing it. I'm on a 3 weeks vacation so I will have to follow up that issue when I come back. Will keep this thread updated
Hi folks. This issue is especially seen in Apple devices. I can tell you that in the past I have fixed this symptom by upgrading the firmware in the endpoint devices.
Hope this helps.
-J. Maxwell, CCNP Enterprise
Still no luck with 28.6 nor 28.6.1 ( the code is identical to 28.6 ) Going to test 29.1 soon..
We are seeing the same issue on our network with Macs (Everything up-to-date Monterey). Some of them use 802.11r without an issue but with others we see quite a lot `invalid_pmkid` errors in Meraki connection log.
Hi !
Have you tried messing with 802.11r ? Enabled , Adaptive ?
We have it set to enabled. We observe PMKID errors mostly with first gen M1 machines which should support 802.11r.
We currently only have iphones and ipads. I will have to try to set it to adaptive.
