Hidden SSID on my network?
MarcAbaya
Yesterday, I was testing my new WIFI scanning software (inSSIDer) and notice that my APs are broadcasting a hidden SSID as shown below:
I don't recognize those MAC address but they are showing as Meraki and it's using the same channels as my APs. I check my list of SSIDs to make sure but they aren't. They are also not hidden in "SSID availability". Any ideas how to check this?
7 Replies 7
MarcAbaya
I also want to make sure that this is not just a bug for the INSSIDER software.
jdsilva
It's the mesh SSID. You can disable it under Network-wide > General.
I agree with @jdsilva it is for MESH networking - but I don't believe it can be turned off via the Dashboard.
NolanHerring
It can be disabled, but I believe you have to request support to enable the toggle for it though. You did in the past anyhow. Not sure if they've defaulted it to being view-able for all or not.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
SteveLilley
Just browsing
This Mesh setting appears to be enabled by default now. Nice! Now I can turn it off without opening a case with Meraki support.
hk
I can confirm with latetest SW 29.5.1 and New "Design Dashboard" enabled,
that the Mesh check box is per default there, and that the HIDDEN SSIDs go away when Mesh is set to disabled.
MacuserJim
Those are used for mesh routing and I believe some may be for how MRs handle band steering.
