Template issue
josejmto
Template issue
Hi
I made a template, and when my customers connected their devices and the devices were registered on the cloud, I saw that the template was bound to that network, the network template appeared in red.
Why do I not receive synchronization
You need to specify the management VLAN under Configure > Switch settings. It's not a switch port configuration It's a Global switch configuration.
8 Replies 8
Can you send a print screen to better understand what you are saying?
josejmto
Hey, I've found the answer.
There was an opcion to bind the switch .
The issue right now is that I can't see the ports on MX. it is taht i have to bind a template ? I get and error in SW
On the side on MX i cant see the ports
MX
You management VLAN is misconfigured.
By default, the switch will try to contact Meraki Dashboard on the untagged (native) VLAN. Alternately, you can specify the management VLAN under Configure > Switch settings. This allows the switch to reach the internet via a trunk port.
josejmto
I hve the template trunk native vlan 10 . I can not understand you .
josejmto
 i fix the vlan 10
I get this error
i get BAD ip Adress
There is a how to resolve this error. Click on it and you can read more about it.
josejmto
thanks for your support
