HP Wireless Printer with Meraki Authentication 802.1X RADIUS
watdee
What would be the settings\procedures in order to get an HP Printer working with Meraki 802.1X authentication?
8 Replies 8
Adam
It may be possible to get 802.1x to auth on devices that support it but we run a separate dedicated wireless network and do mac whitelisting since most devices don't support 802.1x.
watdee
I ended up doing exactly that while waiting for an answer here but it seems less secure.  Someone could spoof the mac address to gain access, correct?
These are the instructions I used https://documentation.meraki.com/MR/Splash_Page/Using_a_Sign-on_Splash_Page_to_Restrict_Wireless_Acc...
You should use PEAP.
watdee
It's not in front of me at the moment to try out but if I use PEAP, what would I put in the server id field and do I need to do anything with certificates?
Ideally you should only need to put in a username and password.  Meraki use a public certificate, so it should already be trusted by the printer.
watdee
I believe I did try that combination of PEAP and only a username\password and it didn't seem to work.  I'll have to try it again when I get a chance.
It 100% should be PEAP.  Check the log in the Meraki dashboard as well to see if it says anything interesting.
Gumby
I've wasted countless hours attempting to get a pagewide onto our wifi network.
If you work it out, please post back!
