- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Group policy configuration for ISE Integration
Hi
I am trying to provision new SSID for mobile devices by integrating Meraki APs and ISE.
The problem is that I am not able to update layer3 firewall rules of existing group policy. I am getting message below in red. Also getting same error message when I create new group policy.
There were errors in saving this configuration:
- The DHCP relay IP address must be in a subnet or static route in this network.
Please advise how I can fix the error and update group policy.
FYI We had MX100 but it has been decommissioned and no longer available on Meraki Dashboard.
All layer 3 interfaces/routing have been migrated to Catalyst9500 switch.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It seems your network is combined network, so Dashboard is trying to apply MX configuration even though there are nothing in there. I think splitting network into security appliance and wireless network will help you.
Update : I made a typo. I changed "anything in there" to "nothing in there" to make it more clear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks Kamome, the issue has been fixed after splitting network as you suggested.
