Google Chrome Cast Not Casting via Meraki Network SSIDs
UsmanSa
Hello
I am trying to cast my laptop but it does not work. My scenario is that it is a school network.
I have 2 SSIDs configured. 1 is splash page authenticated and the other is password protected. I have connected to both SSIDs but still I am not able to cast my laptop even when both are connected to same SSID. It says 'no device found'.
I tried casting using my mobile hotspot and it worked perfectly. Is there any setting that needs to be done in Meraki?
5 Replies 5
Ssid should be configured bridge mode.
Both devices need to be in the same vlan. The traffic should be allowed in the MR ssid firewall  and layer2 isolation need to be disabled
https://community.meraki.com/t5/Wireless/Chromecast-printing-not-working-over-Meraki-Wireless/m-p/23...
UsmanSa
L-2 Isolation is disabled. Both devices are connected to same SSID as shown below. Its all in same VLAN. Can you clarify on below.
UsmanSa
No nothing like that. I am able to ping Chromecast from my laptop but not able to discover it. I had a call with Cisco TAC as well, they need some packet capture using a MAC book. Currently no luck
ntuccillo
Usman,
I had this exact same issue with Chromecast. Meraki is a little odd with it. What we ended up doing was set up an SSID specifically for Chromecast. We have the SSID running in Bridge Mode. We had to make sure in Wireless -> Firewall & Traffic Shaping to allow anything on Local LAN. After that, our devices were able to communicate with Chromecast and cast to it. I know you mentioned that it had nothing to do with wireless firewall but make sure to double check the SSID because Local LAN is denied by default. You have to change it to allow.
Let me know how you do.
