Floor Plans for MR Access Points
Beaumatthewsj
Hello!
I have a customer that is converting from Cisco to Meraki and they were able to use CAD drawings for their existing floor plans that they placed APs on. They were able to identify the room #s of where the APs were located because the CAD Drawings were such high quality. We are now attempting to get high quality JPEG or PNG files uploaded into dashboard so that the customer can read the room #s on these JPEG or PNG Files so they can locate APs. We have not been successful so far. Has anyone ran into this before?
Any advice would be greatly appreciated.
Thanks!
Beaumatthewsj
I have found a solution. I was able to use a App on Mac called QCAD that allowed me to export the CAD Drawings as a high quality JPEG. Thank you everyone!
9 Replies 9
DarrenOC
Hi @Beaumatthewsj , what error are you getting when uploading your maps?
Beaumatthewsj
When we attempt to upload high quality images they are too large in file size. So we are unable to get a 5mb or less quality image uploaded.
In order to upload a custom floor plan, the file must be:
  • Less than 5 MB in size
  • No larger than 65,448,100 pixels
  • One of the following file types:
    • JPEG
    • GIF
    • PNG
https://www.img2go.com/compress-image
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Using_a_Floor_Plan_...
KarstenI
I am using JPEGmini on the Mac to reduce the file size if the images are too large.
BlakeRichardson
5mb does seem small given file sizes today.
KarstenI
Oh yes! It's more a file size from the last century ...
Beaumatthewsj
